okay so i bought some dc2 sideskirts and i was wondering has anyone installed this on their da. it seems to me like everyone only done ek sideskirts. i searched here and searched in hondatech even google. i cant seem to find anyone that has done this. i know it requires cutting and everything but can anyone help me like wiht a list of materials. i will gladly post pics after it is done. if anyone done this can you post up some pics???
Some pics of my car. I found like 10 threads about dc sides on g2ic with one search. I tried to find some close up pics but i couldn’t find them
screws
double sided tape
cutting wheel of your choice
o wow thanks for those pics. i like how they fit and they dont flare out like the ek skirts. did you cut from the front mudflap?? did you do any cutting on the rear part?
I cut a slit in the mudflaps so the sideskirt goes through them. The length is exactly the same no cutting. I mounted the driver side on the passenger side and the passenger side on the driver side. I did that because the one end of the sideskirt is a little bigger then the other end and it matched up better with the height of my front lip.
o ok so you only cut the mudguards? did you cut the bottom part of the skirts? what size screws did you use. sorry if i ask too many questions.
I cut the bottom part of the skirt in half and i used the same type of screw you use to put the mudflaps on. It’s a phillips head screw with a washer on it.
ok so last question did you cut horizontaly or verticaly on the mudflaps? and did you cut from the middle or like just widened the hole on the flaps?
i want some of these bad!
I cut a slit in the middle of the mudflaps. I actually sold the sideskirts,m if i can find the mudflaps i’ll take a pic of where icut them to show you.
o ok thanks i would appreciate that. thanks for the help.
wow, i’m actually just getting ready to do something like this, just wasn’t sure what sideskirts would work. i heard that a 94-97 accord’s entire kit works front sides and rear, with the front needing to be sectioned in the center.
someone should start a thread of what fronts sides and rears work on our cars and with what mods, i’ve seen a page like that for older preludes. i’d love to see what some people come up with.
[QUOTE=turboB18Ls;2022616]wow, i’m actually just getting ready to do something like this, just wasn’t sure what sideskirts would work. i heard that a 94-97 accord’s entire kit works front sides and rear, with the front needing to be sectioned in the center.
someone should start a thread of what fronts sides and rears work on our cars and with what mods, i’ve seen a page like that for older preludes. i’d love to see what some people come up with.[/QUOTE]
There is a thread like that already on here… just need to search for it… I’m too lazy to look for you…
