my car didn’t come with one when i bought it from the previous owner…and i was wondering is it hard to install, can’t seem to get behind there to tighten tthe bolts
mine broke off, and it was a piece of cake to re-install. I just had to grind off the old bolts, epoxy a bolt into place in the bottom one (i couldn’t get to the back where i would need to put a nut on, so i just epoxied a bolt in the hole to help line up the dead pedal), buy a nut, bolt and washer and secure the dead pedal by the top hole (you have to turn your wheel all the way to one side to get access to where you need to use the wrench/socket.
when you get all the parts in front of you it should be pretty self explainatory.
