del sol seats
ok i have looked, searched and read forums on this subject. my question is very simple. i want to know if the seat pans can be swapped out from my 90 integra to 97 del sol seats. let me know. and yes for those that want to put up SEARCH i read the one from battlecats also. i tried it and it seems that my seats are a little different from those. so any help would be great.
NO but there is a write up with a link to it on how to make them work. I did this about 6 years ago and I am about to do it again soon. Let me see if I can find that link again.
http://battlecat.8m.com/DelSols_install.htm
there you go man… have fun
I had del sol seats in my car… only minor mods and got 3 bolts to fit.
I had all 4 bolted in and working FINE
:whisper: how did u get all 4 bolted in !!!
anybody?? can i just switch the seat pans??
READ ABOVE… NO YOU CANNOT JUST SWITCH THE PANS… They are 2 TOTALLY DIFFERENT seats… YOU HAVE TO DO THE WRITE UP… TRUST ME!!! I am about 2 do another set of seats. Follow the instructions works GREAT…
da9b16 did you get them in???
Nah I put this on hold motor to machine shop today is more important.
line bore, balanced, lightened flywheel, knife edge the crank, shot peen ls rods b18c block, ls crank, with gsr pistons .25 over, with b16 head port matched and radius valve job… new valves, springs and retainers… keep compression lower around 10:6:1 so I can boost on 8lbs without causing problems.
like having an ls/vtec just in a gsr block for the oil quirters…
ok here is my problem with my seats. my car is a 90 canadian gs coupe. the seats instead of having the three mounting points that aim down and one thats straight, all four aim down and look nothing like the seat on the link you gave me. explain to me what i can do or take pics and what not. i need these in the car already. i have a pair of 97 del sol seats from a car that had 20000 miles!!!
Well I have never seen a canadian model teg so I am not sure what the seats look like…
