Re: yes
Originally posted by crazyteg67
yes when i turn my steering or when i open the heater my rpm fluctuate a litle bit, and when i start my engine when is cold he start at 1700-1800rpm and goes back after, i would like 2 know how can i know when the iacv is not working??
Have a friend put their hand on the IACV when you engage the AC or the defroster. You should feel a good ‘click’. If not, one of two things is wrong:
I) you may have lost power to the IAC motor by way of a short, dead fuse or burnt motor
II) (most likely the case more often than not) –> you have carbon buildup on the inside of the assy. You need to pull the IACV off (takes about 1 min with a 12mm wrench as I recall – or was it 11??). Anyway, pull this off and disconnect the two hoses. Spray some carb cleaner or air intake cleaner (better stuff – less abrasive) into the intake screen. I suggest filling the whole thing with the cleaner and letting it sit for maybe 10min. Shake it vigourously a few times and then pour the dirty cleaner out. Repeat this till the cleaner comes out clear and clean.
now that you have cleaned it… look inside at the pintle spring (it will look like a plastic accordian type thing longitudinally mounted)… Make sure this is clean but be carefull not to damage it – this is where a very small paintbrush comes in handy. Anyway, once you are comfortable it’s all clean and ready to go, connect a 9V battery to the terminals at the connector and feel for a good ‘click’ while watching the pintle assy. If it moves noticably and clicks, you have solved your problem.
If anyone needs an IACV I have a near mint one from a JDM B series motor. The reason I didn’t use it was because it needs an extra hole to be bored to mount it. I didn’t want to mess with the head just yet. Either way, I ended up needing tofix my old one because of the fittment problems. It worked just fine.
Try to look at the simple stuff first and then go from there. Another major culprit for these idle issues is the CTS. Perhaps I will do a ‘Teg Tips’ submission for this to show you all what I am talking about. I could include some shots of the oscope reading also to show you what’s happening as the thermosistor operates and how this affects the output of the ECU.
Good luck and let us know how things are going. If anyone cares about my old idle woes, they’re are almost completely gone. My only last course of action to stop a little hood shake is to replace the front lower mount. I have a new one but have been too busy/lazy/etc. to get under there and slam it in.
HTH
Andrew.
note: sorry the punctuation, diction, and spelling was so horendous… it’s been a looooong one.
aka neex.
