Difference between g1 b16's?????
A couple of weeks ago my friend bought a 1st gen b16 head that he is planning on using for an lsvtec buildup. Yesterday he bought another b16 longblock because he was able to pick it up for just $450. Anyways, when looking at the heads, one says pr3-1 and one says pr3-3. Do any of you guys know what the difference is?
Sean
1st gen b16’s had 160hp and later versions had 170hp because of more agressive cams. I don’t know which later versions though because the 2000 civic SI is only rated at 160hp so…
BTW, there’s a hybrid forum that deals with engines that don’t come in a g2 and this thread will probably be going there pretty soon.
whiteyg2RS: you are only sort of correct on that info.
first off, all USDM b16’s (b16a2 and b16a3) have 160hp and a compression ratio of 10.2:1
89-91 jdm b16a’s have 160hp and have 10.2:1 compression
the 92+ jdm b16a’s have almost 170hp and run 10.4:1 compression. Their cams are slightly better than the 89-91 cams, but nothing too drastic.
Both of my friend’s heads are 1st gen. That’s why we can’t figure out why one is pr3-1 but the other is pre3-3.
OOO I think I know. One was from an automatic car and the other was from a standard. I believe the auto b16’s have the very least aggressive vtec cams made. Am I right??
That could be. Maybe one was from a crx and the other from an integra??? I really have no idea, does anybody know for sure?
:wink:
Re: Difference between g1 b16’s???
Originally posted by 93gsr
[B]A couple of weeks ago my friend bought a 1st gen b16 head that he is planning on using for an lsvtec buildup. Yesterday he bought another b16 longblock because he was able to pick it up for just $450. Anyways, when looking at the heads, one says pr3-1 and one says pr3-3. Do any of you guys know what the difference is?
Sean [/B]
PR3-1,3-2,3-3,3-4 no difference in casting from what I’ve seen.
Yep, auto b16a’s are detuned with less agressive cams. the 92+ b16A’s have a 2mm larger throttle bodym, better cams and 10.4:1 compression.
