I need a new front bumper for my 91. I’ve got a chance to buy a replacement in the right color but it’s a 93. Am I going to have any fitment problems?
EDIT: Found the “Converting a 90-91 Front bumper to a 92-93 Front bumper” tip. Thanks…
check the teg tips it shows you how to convert the bumpers with minor modification.
[QUOTE=roamer;2114993]I need a new front bumper for my 91. I’ve got a chance to buy a replacement in the right color but it’s a 93. Am I going to have any fitment problems?
EDIT: Found the “Converting a 90-91 Front bumper to a 92-93 Front bumper” tip. Thanks…[/QUOTE]
All you need is all the stuff for the 93 bumper. The Support, foam and bumper. Everything will hook up. The bumper lights might need to be changed to the 93 socket,but that’s a simple job
The only thing i used to switch from 90-91 to 92-93 is the foam piece. I didn’t have to use the support from a 93
The 92/93 support is a lil different then the 90/91. Yea you can use the 90/91 but the bumper might not set right and there might be a gap.
Perfect fit after a couple minutes of adjusting.
