I have the same setup on both right and left. What bushings or reasons would cause my camber valves to be off by .4 degrees? I have -2.0 on the left and -1.6 on the right. Or is this normal? Thanks guys
Check the springs, as I’m assuming your car is lowered since you have that much negative camber. Different ride heights left to right will give you differnet camber values. Also, check the big rubber pad under the upper mounting base. (The rubber shock pad that sits between the spring and shock, to see if one is more deteriorated than the other.)
Also, check the shocks’ lower rubber bushing, that connects the shock fork to the LCA. Also check the upper A-arm at the ball joint. If that’s banged up in any way, it’ll give you different camber values.
