Is it normal to have different idle tone with the clutch in and out…it seems that when I let the clutch out to just sit in one spot the idle seems to ‘come down’ a bit. not sure if it means anything, or if i just need to adjust the cable a bit…thanks.
that is just the power it takes to move the tranny internals, oil & the clutch.
thanks…mods close this thread, or can i do that?
there may be that you tranny needs to be adjusted, mine did. the plate was hitting the flywheel in nutral and was grinding a little, i readjusted and works fine now… well better that is!
