Different turn signal problem
FCM help me out man…
My hazards work, as does my right blinker. The problem is this: In order to get the left turn signals to work you have to hold the [thing on the column] in a certain place, and if you don’t get it right they don’t do anything. Also there are some grinding noises while you try to find the special spot.
The fuses are all good. Any ideas??
You will need to replace your signal light switch.:dozing:94
erm is that in the column? like the mechanism that the arm (you use to signal) controls?
If that is what you need, I’ve got one for sale. My e-mail is rollinmyda@yahoo.com if you’re interested.
Yes, it is part of the “Combination Light Switch”, although on a G2 I believe the signal light and head light switch can be separated.:whisper:94
