Let me start by saying hello, yes I’m new to G2IC and I’ve had my teg for about 6 months now. Lots of helpful information here, and I have done a lot of searching about.
Now on to the topic at hand… I’ve been spending copious amounts of time sweating like a slave disassembling my interior to fix the minor problems in my G2 and to dye my panels/seats in the scheme I want. So far everything has been fairly easy, with the exception of the seats.
I am actually having a hard time trying to figure out how to remove the seat cover for the lower portion of both front seats. The top cover was easy enough, but I can’t seem to be able to remove the rail assemblies and separate the seat parts to get to the cover. I would really REALLY like to avoid tearing my covers.
EDIT: This is where I am at right now: Top cover is off, hog pins and the plastic clips are removed from the bottom cover, shoulder belt assembly is removed and corresponding nuts as well, slider arm cover is not off (I’m assuming it doesn’t come off unless it or the handle are broken) and is in the way of a 12mm nut holding the rail housing to the seat frame. Everything else is still assembled, and the top and bottom of the seat frame are as well. Where should I proceed from here? Remember I just want to get the covers off.
