I need to know which fuse to pull to disconect abs motor getting sick of the clicking noise thanks
JAY
i dont know about the fuse for the motor. but the one for the abs control unit is under the hood. theres a ABS B1 (20A), ABS B2 (15A), and the ABS main relay (40A) its one of the screwed down ones.
ya I pulled the 40A ALB main relay fuse. Seems to have shut it down
Thanks
JAY
ok if u still need to know about the abs motor relay. i found out. its under the hood on the passenger side. right in front of the fuse box towards the front but not past the battery, u can see 3 relays there right on the top side. the abs motor relay is green, abs front fail safe relay is yellow, abs rear fail safe replay is orange.
