Ive almost got the engine out,just need to take off the axles and that cable that goes into the tranny.
Can anyone tell me how,do i just unscrew it?
Ok… theres a little rubber boot that covers the speed sensor. Pull that up to where you can see under it but be careful not to tear it. Then, you will see a ring that wraps around the speed sensor. All you have to do is take that ring off either with needle nose pliers or with your fingers. BE SURE NOT TO LOSE THAT After you have that off it should just slide out (maybe with a LITTLE force)
If i missed something someone please correct me. HTH
Dev
