I need help, Im installing new rotor, cap, spark plugs and wire and I cant and dont know how to take the rotor off, someone please help me out here…quick!
thanks
thanks
There is an allen bolt that is screwed through the rotor into the dist. shaft, you need to click the engine till the allen bolt is facing an area you can remove it. Make sure you use Honda parts and make sure you put the allen bolt back in…
