distributor installation question
im just getting done replacing mt head on my 90 ls auto non v-tec (ya i know u dont have to say it) and im at putting on the distributor on and i searched maybe not good enough but i need to know what side of the cam dose the line go the cam is at tdc(top dead center)
this one is blury but it dont matter u get the point
just put it on, if it runs weird switch it
did that with my built Z6 and worked fine, all it will do is cause your firing order to be backwards
it only slides on one way, if you notice that notch is offset to one side
^+1 if it slides in easy and sits flush you’re golden. If it won’t go on, turn the distributor drive 180 degrees and try again.
+2 on the previous post… I was going to ask this question when I was installing my distributor but decided to just try and install it… It only goes in the one way easily at least… If you find yourself trying to force it, then you’re putting it in 180 degrees off… HTH
thanks guys for the help. i noticed that it would only go one way but i thought i may have been fuckin up some how but i got it.
