i just recently did a valve adjustment. i was driving my car a good 45 minutes away and when i got to the last toll booth my check engine light came on and the idle was going nucking futs. so i parked it at my friends house right down the street and then worked on figuring it out. when i started it up it seemed fine then i heard a whining sound. it was coming from the distributor.
i took the cap off and noticed the rod holding the rotor on is loose i could wiggle it. so i took the coil pack off to see wat was up and noticed there was a gyro sorta thing that holds the rod in place while letting it spin. well from what i could see there were two screws that should be holding it tight… well only one was there and it was almost about to fall out, so i tightened it and my car ran fine for a day. now its doing it again every now and then, i need a permenant way of fixing it but don’t want to buy a new distributor…
is it possible my timing is off and caused this to happen?
CEL? i’m guessing code. well i don’t know how to do that, never had to before and like i said the light doesn’t always come on and when it does i shut the car off imediatly cuz the engine rattles bad
What year is your car? If it’s 90-91, turn the key to “on” and lift the carpet on the pass. side to expose the ECU and count how many times the red LED light flashes…the codes are listed on here. If it’s a 92-93 you will have to use a paperclip to jump the harness and then look…better instructions are posted on here, just search. Even though you aren’t getting a CEL you should check for codes anyway, never hurts.
So basically something is messed up with the distributor since Im pretty sure that that sensor is located in the distributor. Have you even tried putting in a second screw in that spot? I would probably try to do that first since obviously if something is physically wrond with it its probably going to mess something up.
You could look in the For Sale forums on here for a used distributor, if you don’t want to spend the money on a new one yet, and that would at least fix your problem for a while…
i’m not sure how to take it apart to look for that i found some screws i think would take it apart but there star patterned with like a little circle in the middle so the star patterned tools i have won’t go in.
