[SIZE=“4”]HOW TO REBUILD THE SPEED SENSOR[/SIZE]
TOOLS NEEDED:
10mm socket and ratchet
Bottle of supper oil or motor oil will do.
Small flat hear driver
A set of "O"ring from any auto store
WD40 to help clean out chambers.
A rag you don’t care about getting dirty.
FIRST
Locate the speed sensor on top the transmission,its where the starter is but next to it up by the firewall. There is a 10mm bolt holding it down. You will need to remover to lock pin that holds the speed cable in place and unhook the oil feed lines.
Now that you have it out,there are 2 10mm bolts that you take off.
Now pull it apart but do it slow so nothing pops out on you. Here is what it will look like.
You will see 2 gears inside the housing,pull them out but look out,there is a pin on the shaft that you need.
Here is it taking apart.
Now pull the gear/shaft out.
Now hold up the bottom part of the sensor,you will see a center piece that keeps the shaft in place,with a small flat head,pull it out without scratching the shaft.
Now there is a small seal inside the housing that looks like a crank seal. You can get this at any Honda store.Push it out with out scratching the wall. Use a socket to push the new one in.
Part#91313611010/cost is $2.54
You will also need to replace the O rings. One is a big one inside the housing and the other is on the part that go’s in the transmission. I got this O ring kit at Auto Zone for 5 bucks.
Now the top part of the sensor,you have another little seal that is different then the other one but looks the same. Push that out and with a socket,push the new on in. Part#91304/pt0/000_cost is $3.02
