hey guys, i am planning to swap a b18c2 into my DA. do i need to change my engine mounts or can i use my stock ones??
Use your stock ones, you just need the driver side mount bracket(the part that attaches to the block). And I think you need to use the stock rear bracket, someone else will know for sure about the bracket.
thanks alot man!
which tranny are you using
an LS… oh yea, my clutch kit just came in for my LS tranny. would it also fit a GSR tranny?
If the LS tranny is a 92-93, than the clutch disc will work but the pressure plate and throwout bearing are different because your tranny is cable and the GSR is hydro. If you were to use the GSR tranny with the correct clutch kit for that than you would need the cable to hydro mount kit from someplace such as Hasport or Innovative or Avid Racing.
oh ok that helped alot guys thank you very much!!
