im lowerd alot and i got a engalls 3 degree kit, its pulled all the way out and its still negative, does anyone make a 4 or 5 degree? if not ill take the engalls off and sligtly grind more sliding room, but not too much where breaking is involved, i need an alighnment, but pointless till i get a new camber kit
nope no one makes anything over 3 degrees. the only way would be to combine two camber kits. use the skunk2 control arm camber kit and the ingalls, and you should be able to adjust +6/7 degrees. but then the control arm will definitely hit the fender.
i dont even think skunk make a kit for our cars yet, its of maybe 2 degrees. but i hate tire wear, i think its the alignment that killing them, i may take the englass off and grind the gorrve thing out a few more mills and itll help more, i mean i know its voiding the warranty and structure, but every little helps alot,
