does this sound like rings??
ive had my DA for a while now but the car hasn’t been on the road only like a few times. the motor just had a ported n polished head, new valve seals and ARP head studs with a new head gasket. well i started the car the other day and it just smokes and smoke. the car is burning oil bad. yeah its blue smoke. it smokes so bad that you cant even see the back of the car and that is with the car just sitting. so what i want to know is, are the rings bad in my car or can something else be the problem?
Bad valve seal (doubtful) or the head gasket isn’t on right. Check those first. I’m assuming you didn’t have this problem before the head rebuild?
:getsome: :manual:
or even a bent valve. You can try a comp. test. The valve seal my not be on right. I ran into this problem once. And it was a bent vavle and raised the valve seal up. Smoke like a mo fo…
