So I put in a LED dome light in my 92 teggy yesterday and when I installed it it was working fine. But when I get in my car to go to work this morning it didn’t work. Even I switch it to ON it still didn’t work. I don’t have the fuse box cover so I don’t know which fuse is for the dome light. If anyone got a picture of it that would be nice thanks. Or if u think another problem can cause this please let me know thank u
Will get you the fuse number as soon as I get home, maybe the new LED light is N/G. 94
Fuse #14 is dome light, also front map lights if you have them and the trunk/hatch light.
Does the trunk/hatch light work? 94
im not sure if the trunk/hatch light works. i will double check when i get home thanks.
how do i know which fuse is #14?
Your Google search found this… http://www.acuraworld.com/forums/f74/noob-help-1990-rs-fuse-diagram-65151/ 94
i figured it out. thank you
[QUOTE=92da408;2085592]i figured it out. thank you[/QUOTE] What was wrong??? 94
yeah what was wrong because I’m having the same problem?
