Dome light question
When I open my driver side door…the seat belt retracts and the dome light turns on. When I open the passenger side door, the seat belt retracts but the dome light doesn’t turn on. How do i fix this and whats causing that?
its your door switch. if youre sitting in the passenger side, look on the door frame, and youll see an “L” shaped plastic thing. if you push that back and forth it will turn the light on and off whenever the door is open or closed. if it doesnt work, then the switch needs replacing.
