door creaking...
Wzup fellas…my drivers side door creaks when ever I open it fast. I sprayed the hinges with tri-flow (has teflon) bit it still creaks. any secrets to quiet that ish up? Thanx
-White 90 Teg
good ole wd-40. or use a lithium grease on the hinges.
its not a squeak but more of a deeper tone. i think the spray should of worked by now cause i lubed it this afternoon but the noise persists. how the hell can i fix it?
-White 90 Teg
hmmm, its sounds like metal on metal…i thought it was just a hinge in need of lubing…did you check the front of the door (where everything meets) to see if anything was rubbing?? kinda sounds like the door has been messed with before.
It was the hinges. The lube just needed some time to settle in. Thanx y’all.
-White 90 Teg
