Door Detent Removal????
Has anyone removed and replaced the Door Detent Rod? Its the little arm that prevents the door from swinging open too far and also holds the door in place when opened. Any help would be appreciated.
i think u gotta take out ur whole door to take it out…
no man just knock the pin that is in the pillar out from the bottom and undo the two ten mil bolts that hold it in the door and let it fall in the door
you gotta take off the door panel and the speaker to get it out of there
i actually left mine off and the door swings open like almost 80-85 degrees you just gotta be careful when you are on hills but it helps me get my big ass out of there easier
to remove it is easy. I want to know if someone has done it and has a really good idea as to how to replace it with another. I guess I could use your steps though, I would just attach wire so that I can pull the lugs back through so that it can be rebolted on with the replacement.
Anyone else have an experience at this. let me know.
NFULLFX…
TEG TIP here.
To replace your door detent.
~REMOVAL~
Open door wide
raise your window all the way to the top (this will allow full access into your door.
remove the speaker grill cover
unscrew your speaker.
unplug your speaker and set it aside.
unscrew the speaker housing/holder.
pound the pin gently with a hammer.
unbolt the broken detent using a 10mm wrench.
reach inside and take the old one that dropped.
~INSTALLATION~
place the replacement detent inside and bring out the arm.
hold in place and replace the 10mm bolts back on.
If your detent arm is out of alignment, place it against the mounting area and gently close the door enough pushing the detent in and then replace the pin.
Replace the speaker housing/holder.
plug your speaker back in.
Screw your speaker back into place.
Replace your speaker cover.
Time: 15min max.
Difficulty: Easy.
