Can anyone provide some hints how to remove the strain relief and the electrical connections/wires passing from the body into the door. The door is still on the car and my cage is preventing me from getting a clear view into the door to see the connector/strain relief. I can reach in to the door openings and feel the strain relief but can not pull the electrical connections out of the door.
Thanks!
theres 2 plugs on each side. then sort of a connector in the door that comes out seperatly.
pull the pin out of the door stop and you should be able to swing the door open a little more, removing the fender makes this whole job imensly easier.
I might have some pictures that would help
whats your email
Hello BLKACK1,
Thanks for the help, pictures wouid be great, m_sasso@shaw.ca
For sure take the fender off, then you’ll have a good amount of access to it. If Gylnn doesn’t have the pics, I can snap some real quick (I’m pulling a harness right now)
you might be able to get them from agazzi before ill be able to post up.
At work all day:(
Please take those pictures and post them up, I am going to give it a go again this weekend, Thanks!!!
Hello Mrpenny,
Thanks very much for the pictures!
Now I know the connector lock is on the bottom should make it much simpler to unplug the door harness.
thats the one, mine actually had 2 plugs on each side, but i had P/everythigh
[QUOTE=DB2-R81;1872612]Hello Mrpenny,
Now I know the connector lock is on the bottom should make it much simpler to unplug the door harness.[/QUOTE]
Hey it was no problem, I had to do it anyways so might as well help someone out eh :rockon:
Really, what trim was it? The 4dr has power windows and locks but only one plug, but it’s only an LS
I could be wrong, is been months since ive done that.
mine was a gs P/W and P/L
[QUOTE=BLKACK1;1872931]I could be wrong, is been months since ive done that.
mine was a gs P/W and P/L[/QUOTE]
Yea I just looked at that GSR door harness I have and see what you were talking about
