all the doors and hatch in the bacc is close and i still have the door light on at my gauge.how do i fix this or just turn off the damn door light on my gauge very irriritating.thnks
Does your dome light stay on? Probably a problem with the little switch in the door jam.
grease up the little L shaped piece in the door jams
:iagree: :werd:
Those door switches go bad all the time. If you remove them and push the harness back into the hole you will never see the dash light again (what I did).
Greaing the senders may work, but replacing them is the best answer.
