It’s really hard to tell from the pictures you provided. But IT SEEMS like it’s either or a combination of having positive camber (upper control arm) and being toe’d out (tie rods). But again the pictures are hard to distinguish what’s going on…
OK. Tell me about it. I keep going on the passenger side to see if any thing is different. Hard to tell. Hopefully by the end of the month I should have a parts car and see if anything is off and maybe find out what else is bend.
Things can be bent a few degrees and you’d never tell by looking at it.
I’d fork out the dough for an alignment tech to look it over and give a diagnostic on it.
[QUOTE=unified112;2317052]Things can be bent a few degrees and you’d never tell by looking at it.
I’d fork out the dough for an alignment tech to look it over and give a diagnostic on it.[/QUOTE]
Okay will do. I’ll probably get it look at this weekend.
Like AV mentioned, looks like positive camber on the front wheel…
Here are the readings
Front left. Front right
Actual before specific range. Actual. Before. Spec range
0.6. 0.6. -1.0 - 1.0. Camber. -1.1 -1.1. -1.0 - 1.0
-2.9 -2.9. 0.5. - 2.5. Caster. -1.4. -1.4. 0.5. - 2.5
-0.03. 0.32. -0.08. - 0.08. Toe. -0.04. -0.05. -0.08. - 0.08
6.2. 6.2. SAI. 8.8. 8.9
6.8. 6.8. Include Angle. 7.7. 7.7
Front
Cross Camber. 1.6. 1.7
Cross Caster. -4.3. -4.3
Total toe. -0.07. 0.27. -0.16. - 0.16
Rear left. Rear right
Actual. Before. Spec range. Actual. Before. Spec range
1.6. 1.6. -1.7 - 0.3. Camber. -3.3. -3.3. -1.7. - 0.3
0.06. 0.05. 0.00 - 0.12. Toe 0.14. 0.16. 0.00 - 0.12
Rear
Total toe. 0.20. 0.22. 0.00 - 0.24
Thrust angle. -0.04. -0.06.
