driver motor mount fitment issues
ok so i bought some ES motor mount inserts and was in the process of putting them in when i realized my driver motor mount was destroyed…so i call up a local parts store who carries em and i get it, and compare the two and they’re pretty close side by side.
So i begin to install the new mount and i run into fitment issues. Apparently the 2 holes that bolt the mount to the bracket on the block are 3/4 of a hole off, of course i can shift the motor around to get it close but its still not enough.
i tried both ways of bolting the 2 bolts of the mount on first and trying to persuade the long bolt and vice versa by either manually having someone move the whole engine over for me or trying to adjust it with the jack to line up but i can’t get it.
did i get the wrong motor mount or something? or do i have to unbolt one of the front or rear mounts to get it to shift enough to line up?
Bump om having same issue i wuld luv to no. i have a 92 teg and i gota mount off of a 91
the 92-93 mounts are different and the parts stores can not get the right one. your only option for replacement on these years is the dealership. it’s gonna be expensive!
the auto stores all have their mount listed as 90-93 integra, but they only fit the 90-91. your just gonna have to dig deep into your pockets. mine cost me about $165.
