Driver side Wheel Well
I finally got around to buying a new splash guard for the drivers side wheel well because the previous owner of the car screwed up the car and wheel liner.
As you can see in the picture (nevermind the zip tie and spider web), it is bent up where they hit one of those giant curbs at the gas station next to the pump.
I want to put the new one on and it doesn’t fit because it is bent.
Should I use a hammer to bang it down or use vise grips and try to bend it down? The fuel filler is right next to that section and I want to make sure I don’t jack that up.
Anyone have a pic that shows it stock? I looked on the other side but it seems different?
Any help would be great. Thanks.
yeah i think you got a problem there. :angel:
you could try and heat it up and hit it with a hamer, i dont know if a hammer will do it alone, hell if it comes down to it you can always cut it out:shrug:
here a couple i just snapped from the shell in the garage
it is the rear drivers, rear side right:think:
Yes, it is the drivers side rear wheel well.
Thanks for the pics, I can at least get it close so I can install my new liner.
