Just curious if anyone knows if there is a huge difference between the sedan and coupe versions. My db has a window that is hurting bad and needs to be replaced.
Some one correct me if I’m wrong but I think there’s a slight difference in the bottom aft part of it… probably wont work. Never tried it though.
i’m going to take a wild guess and say that the coupe windows are longer
The actual motor itself is probably the same…but I doubt you can interchange the rest of it.
