Me and my friend are trying to drop the integra and while we pull the springs out we moved the cv axle it would not go back in any help would be very helpful if somone can tell me how I can put the CV Axle back in
Also could this be becuase one of my other friends wwas shifting gears while the suspnesion was takin down from the upper arm
You did not have to tear down the suspension to get the spring and shock out.
What do you suggest I should do.
It should slide right back in place.Ther is a clip on the end of the axle that snaps it in.You should hear it click when you push it in and make sure you check the fluid.
