I got a Lanzar 1200D and 2x Clarion SRW3881, what would be the best way to wire these to the amp since they are dual coil.
subs - http://www.clarion.com/products/subwoofer/subwoofer1.htm
how do I wire it so it’s 2ohms
With the speakers you have (dual 4ohms) you can only achieve a final load of 1ohm (parallel) or 4ohms(series/parallel). Your amp is a mono amp and is stable down to 1ohm. So from your drawing, the only one that looks to be wired rite would be fig.2 and it would drop you down to 1ohm. Not sure if your subs would handle that so you might try running the amp at 4ohms
Your subs decide what final ohm impedance the amp sees, not the amp. So a sub acts the same at 1 million ohms as it does 1 ohm. The amp is the one that may have trouble safelly handling 1 ohm, not the sub :). Just a little FYI.
Your subs decide what final ohm impedance the amp sees, not the amp. So a sub acts the same at 1 million ohms as it does 1 ohm. The amp is the one that may have trouble safelly handling 1 ohm, not the sub . Just a little FYI.
Yea i know that, i was referring to the power output at one ohm just didnt make myself clear. Im not sure what his subs actually capable of running. All good
Yea i know that, i was referring to the power output at one ohm just didnt make myself clear. Im not sure what his subs actually capable of running. All good![]()
Yah, I knew you knew that, just clearing that up for everyone else
