yeah i know this is a dumb question but i was just wondering where the hll the windsheild washer nozzels ar located at thanks
under the hood.
and next time use a more detailed thread title unless you want your threads closed.
http://www.g2ic.com/forums/announcement.php?f=31&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
