Duralast Cap and rotor
What are the reviews on these? It looks like when i got a tune up from honda they put these in.
I ask cuz my car will not start. Eveyone has been saying to check the cap, rotor and coil. I check resistance and voltage off the coil and everythign check out okay. So i was thinknkg the cap and rotor are crap. Its not my MFR. Im getting fuel just no spark.
duracrap parts suck. ive replaced cap, rotor and ignition coil and they lasted about 2 months then went out again. the coils always blow out. i finaly went to orileys and bought a new coil, rotor and cap and havent had a problem since. druacrap axles suck to… if you can even get some that fit. they make okay oem replacement balljoints, bushings and brake pads though
[QUOTE=G2Magnus;2161528]What are the reviews on these? It looks like when i got a tune up from honda they put these in.
I ask cuz my car will not start. Eveyone has been saying to check the cap, rotor and coil. I check resistance and voltage off the coil and everythign check out okay. So i was thinknkg the cap and rotor are crap. Its not my MFR. Im getting fuel just no spark.[/QUOTE]
also try looking into the ign coil to see if its all black and burnt out, if it is id replace it
Ya after reading all the threads on here i looked at it, looks sparkling fresh. No burn marks or anything. All i can think of at this moment is crap products. Cus i even have voltage coming off the tip of the ignition coil(where the spring is).
if that doesnt work check the main relay or fuel pump relay
ya, rather than buying a duralast cap & wire set for my wifes celica i drove a few blocks more to o’reilys and picked up one of theres.
i dislike duralast.
check the wires (closely) and plugs themselves… double check proper plug gap as well since you are there already. i tend to recomend NGK wires & plugs, never done me wrong in the past.
Ya well its not a fuel issue. I’ve check and there is fuel. I even check the sodering joints on my fuel cut off switch i installed. Its all working nicely. Just no spark. I’ll check it again anyways. Never hurts to double and triple check things. Thanks guys.
And ya NGK ive had before. Never let me down.
