i just put a b16a into my teg. i noticed the ecu is turned the opposite way as stock. what should i do to get the wires to reach over to the other side? can i just bolt the ecu dwon with 1 nut and then just puyt the plate over it? i dont see any other way to do it.
thanks
That’s all I did… put the ECU in the top left hole and then
just use one nut to tighten the plate down. Works fine. HTH…
