ok the found out when you have the valve cover off there 2 holes in the cams just find something that fits down in there snug and ur cam gears wont move wen putting the belt on…hope this helps
Do you think you could be a little more specific?
i did this as well…no specifics though because i dont know the name of any of the parts…
according to the helms you can use like wooden dowels or something to hold the cams in place. I don’t remember what they called them exactly as I’m at work and don’t have the helms here.
:gotpics:
1 hole in each cam. put something in there like a punch = 0=== :naughty:
that’s just not the same as you could have done in MS Paint man… :dunno:
Sorry guys, I read what he said wrong. At first I thought he said "I found an easy way to get your car in time while the valve cover is still on the head. Yeah I know I should have read it better. Sorry. And just to let you guys know I do know that you have to have the valve cover off to put the belt on. Unless you have a valve cover with the cutouts for camgears!
