since ebay intakes only have two connections which two do i connect? and does it matter which goes where? do i have to make a third or can i put a breather on the connection coming from the valve cover? sorry i just never bought an ebay intake but dere hella cheap… thanks.
You can put a breather on the valve cover but if you can avoid then do!
what was each hose for again?
:idea: Why not use a “T” fitting and connect all 3?
hahaha dee dee dee… didnt think of that one… would it matter which 2 went onto the T?
Should’nt really make any difference. It’s all going to the same place.
So long as you don’t use any of the breathers, you’re fine
cool thanks mang… how are the ebay intakes?
i bought a DA sans intake and the ebay was cheaper than stock so i picked up a cold air setup. it had one 1/4" port and one 3/8"
ran the valve cover to the 3/8 and used a ‘Y’ junction to couple the other two into the 1/4.
No complaints so far
I got a cai from ebay, for the most part it works but made with thin walls. I wouldn’t buy another one though. Next time I’ll spend the money on a good one.
