ebay top hat question
So I have ebay top hats for my coilovers and is it normal that theres no lip for the spring to sit in? When I crank the top down it makes the spring sit off center? Has anyone else ever had this issue? Or should I just go with oem top hats? Otner problem with that is the front ones are discontinued. . Any ideas?
My ground Control didn’t have a lip for the spring to sit in. With that said I had a spring isolator to keep it center hope that helps. So if you have your spring isolators then use them and it should help…
yea, my gorund controls didnt have a lip either. i just tightened it down and the spring sat flat. maybe your doing it wrong. the top and bottom of the spring are flat so i dont see how it can go on crooked.
