my car has been throwing me the code 43 which is the fuel supply system. But i dont know what it is that i need to change or fix. if anyone could help me out that would be cool thanks
Did you even make an attempt to search first before posting? This code has been discussed many times now and ways to fix it.
na man i didnt even look
Well then maybe you should try searching first. :roll:
how do u reset your ecu?
Have to unhook the ground wire, it’s just under the reservoir for your headlight fluid
Search!
thanks
Just go look in the TEGTIPS right above u where the integra Logo is. Most stuff are covered.
thanks again
[QUOTE=renegadex96;1693877]Have to unhook the ground wire, it’s just under the reservoir for your headlight fluid
Search![/QUOTE]
WHAT AN IDIOT! its under the blinker fluid reservoir DUH!
