I put in my intake a couple months ago and never reset any codes…I didnt know I had to. What code do I reset and how do I do it? (I did a search but found several different things that confused me)
ECU RESET
Pop da hood locate fuse box. Pull out the ECU fuse. There should be a sticker on the fuse box that says which one is the ECU fuse. Leave the ECU fuse out for around 5 minutes.
Put the fuse back in and start the car. DO NOT TOUCH THE GAS. Let the car warm up to FULL OPERATING TEMP.
Turn off the car and restart it again. DRIVE HARD.
The ECU will now begin to remap everything as though the intake isn’t even there.
Good Luck!
Next time, check the Teg Tips if your search doesn’t turn up the results you want.
thanks guys
