ecu problems after resetting it!
Im not to good with the ecu i reseted it and not the car will start up and die,and tips, hints,thanks.
Mine was giving me problems too. Reset the ecu again. This time take the ECU out when the car is cold, leave out for 15 mins r so, then put back in, start the car till it reaches regular idle (after initial warmup) then turn engine off. Remeber to NOT have anything on, don’t touch the gas, brake or any other pedal also. Then start up again. Should help you out.
