ECU usage.
I need a stock ECU so i can pass smog. becuase my ecu is chipped its making it fail. Does anyone know what ECU will work with a 92 gs-r what model i should be looking for. thanks
Um a stock 92 gs-r ecu.
you could cut the jumper and then solder it back together once you pass smog
^could you explain more detail?
The stock ECU is P61 from the 92-93 GSR.
Is your chipped ECU a P61? If you open it up and look inside, you can find a spot labeled J1. Cut this and it puts the ECU back to stock.
i bought a stock chip and put it in, at first it started then shuts right off. now the car is running like their is no chip at all. cant go past 3k, idles like shit. I think i need a new ecu
