Ecu
Anyone know if I could use the USDM ZC ECU on my 1990 Integra… it has the B18A…
you can but it wont good
ecu
why not? what will be the disadvantages…
as well, will an ecu from 89 and older integras work?
Re: ecu
Originally posted by jmack
[B]why not? what will be the disadvantages…
as well, will an ecu from 89 and older integras work? [/B]
i think our ECU would give more fuel? iono… and shouldnt the ECU for a ZC and a 89 teg be the same? its the same motor… basically
A friend of mine had a jdm zc set up, and used my chipped 90ecu, it worked better than the zc ecu, yes you can plug up a zc ecu into a g2 w/ non obd wiring,but why downgrade? the jdm zc produced 130hp, the usdm one you are talking about came from the 86-89 integras that made only 118hp. and no the motors are not the same cause those motors are 1.6L
