ef ground controls on da?
my friends got some ground controls off a ef will they fit on my da and if they do will they handle the same since my da weighs more?
In a stock strut setup the EF strut is shorter then the DA’s. But because of the height adjustment control of after market suspension some manufacturers use the same suspension and they can either go on an EF or DA.
Handling you’ll be fine. Just slam it.
