is it possible to put ef hatch si seats in a DA if so can i get a write up got some si seats just sitin around thnkz
well if you have the seats, why dont you try and see if they fit
:werd: if u rip out ur stock seats, and try fitting on the ef seats with the ef brackets still on them, you’ll be able to tell what needs to be done just by looking at it. u can see what holes line up, and which don’t. then its kinda common sense on what u gotta do to make them fit. either take ur stock da brackets and put them onto the ef seats with bolts or by welding it.
NO THEY DONT FIT. tried since no one could answer it. im sure people have tried. the bottom will fit but the back rest wont. dont even try. its a retarded fit and will not look good with modification.
ef si seats look good in Da’s when they are installed correctly.
