Electric window gone bad ?
The other day I went to go ahead and put down my electric passenger side window and it wouldn’t go down. So obviously something is broken, How do I tell if it’s the switch or the motor?
-Thanks David-
Help?
check the fuse lately??
if its thew motor MOST time it would have gone bad slowly
if its the switch it will work on one switch but not the other
if it’s not the fuse not the switch, check the wiring stright to the window hook up a postive and a negtive and see if it works. if so ,itz not the motor
If you are cough “lucky” like me it the wire harness, and if that the problem go by 50 feet of 18 or 16 gague wire and a huse holder!!!
also make sure you didnt just accidentally lock the windows on the drivers side window controls
:bow:
