last night me and a few buddies were cruising around, stopped in a gas station and my car wouldnt start, i had full power it was like the starter solenoid wire came off was not that, so i rolled back and pop started it, then my alternator belt broke, got a new one replaced it then, then it was doing the whole not starting thing again… popped it went home
then tried it again this morning and still acted like the the solenoid wire was off, searched here and thought maybe the starter relay, went to napa and got a new one(tested for power and its good), wasnt that, i replaced the ignition switch 4 weeks ago and its good, tested the starter signal fuse, and no power and also its not the clutch engagement switch(jumped it and tested w/ no avail)…
my question is does the main relay send power to the starter signal fuse or control that in any way?
also i pulled the main relay and it smells mildly burnt
and the relay says RZ-0042 thats what the 86-89 Integra’s call for
and the 90-93 Integra’s call for RZ-0063
is ran for the past 6 monthes ive owned it and i dont know how much longer before that
any info would be greatly appreciated!!!
