Hello, I have a 91 integra with a b18a1 engine. Recently, I have noticed a few electrical issues:
I have two radiator fans, but one fan tends to run when the car is off.
When I go to turn my brights on my lights turn off.
I’m new to these Integras, and I don’t know how to even check these issues.
Thanks Colin! I appreciate it!
Which lights turn off when you turn on the high beams? The headlights themselves or interior lights?
Have you checked the bulbs themselves? On our cars we have dual filament bulbs so when you switch to high beams the low beams go out. I know it seems unlikely that both would be out but it happened to me recently. Both burned out within a few days of each other.
Have you checked your fuses?
[QUOTE=rollinmyda;2314407]Have you checked the bulbs themselves? On our cars we have dual filament bulbs so when you switch to high beams the low beams go out. I know it seems unlikely that both would be out but it happened to me recently. Both burned out within a few days of each other.
Have you checked your fuses?[/QUOTE]
No, ill check my fuses and bulbs. The previous owner also had the horrible aftermarket one piece headlights, that I believe are pulling a lot of power from my car. They have the fog lights, normal headlights and these halo lights going on at the same time.
