I was wondering if the holes behind the emblems will allow water into the trunk? I searched the forum but couldn’t find an answer.
thats a pretty small hole for water to go in unless u spray water right at it. not quite sure where it goes to but it shouldnt be that big of a leak if water gets in it. if u want to make sure just stick some bondo in there.
Ok, thanks.
putting bondo in there is the worst and stupidest thing to do it just absorbs moisture! if you can not properly weld the holes closed them get some 3m clear automotive tape cut out circles in the shape if a penny and stick them on for now that will keep out moisture
