Hi folks, let me introduce myself first. The name is Adam and I am new to the site. I just picked up a bone stock 135k miles 1993 Integra GS-R a few weeks ago. I did cap, rotor, wires, plugs, air filter, valve adjustment, and a fuel filter as soon as I got the car. I took it to get inspected, and it failed emissions for excessive HC.
Idle: 220ppm max Reading: 266ppm
High Idle: 220ppm max Reading: 244ppm
After seeing that, I replaced the O2 sensor with a Denso oem replacement. Disconnected the battery, reconnected it after 5 minutes, and drove it for about 50 miles. Went through inspection again, and I had nearly identical readings. I am now not sure where to go from here. All the other readings are within the proper limits. Its a sweet car that I would like to keep stock. Should I be looking at a catalytic converter next? Or is there something else I can do that would be easier to try first?
The car runs smooth and powerful throughout the RPM’s, no smoke, no oil consumption. Thanks in advance for the help. Also, this is NJ Inspections.
