emissions test w/ OBX High Flow Cat Converter
Just want to know if I will pass with this converter?
There is only one way to find out…
You should be able to pass unless you have something else tuned (timing, cam gears, etc) that would create higher emissions.
Later,
BR
if you get a SAFC or VAFC it could help…
Later,
Tony
I would recommend going to a speed shop that has a motec lambda meter and having your a/f ratio properly tuned along with purchasing a new o2 sensor if you haven’t. I’ve seen ls/vtec’s w/ no cat pass easily after they’ve had the o2 sensor replaced and tuned off the motec so you should be able to as well. also having obd1 helps out a lot when compared to obd0 HTH
